"geez, kid, when are you gonna finish wiring this thing?"
OK, moving along as time allows. What path does the oil level sending wire take to reach the sender? Thanks
Hello again Brian!
From the engine bay along the RH rear side member and down the rear J tube (with the large nut and lock washer) and out through an infuriatingly small hole in the tube, then up to the sender. No photo I'm afraid.
Mick
Thanks.Mick, afraid you'd say that.
