Does anybody have advice on how to clean up a faded plastic door handle? I'm starting at it with some steel wool then trying autopolish. But wondering if anyone else has a better idea or has done this before. Thank you!!
Sunflower oil
Eastwood plastic refinisher works great, leaves a nice semi gloss/ flatter finish
Thanks, Rick
I use 303 Protectant .....
https://www.amazon.com/303-Protectan...473156891&th=1
Hope this helps,
cm
Sonnenblumen oel?
I ended up cleaning then hitting it with a Wurth satin black paint. Came out nice!
the 303 is great on tires and rubber trim.
Thank you!
Make sure you check your handles for cracks. I started to clean mine and someone suggested it to me to check them. I have four of them and three of them are cracked like the pic below.
Attachment 584933
I've had success using the Novus plastic polish kit, usually starting with Novus 2 unless there are deeper scratches, starting with Novus 3 then. I do prefer 303 to Novus 1 as a protectant.
