2 Attachment(s)
Safely putting a 911 on a two post lift?
Guys
Anyone know the safest position to place a early 911 on a two post asymmetric lift?
References supplied with my lift give the recommended lifting points for the 911, but do not supply the car position/direction?
Should the car be engine forward (relative same engine position for a front engine car) or to the rear and where should the car be placed relative to the spotting dish? I have seen photos on the internet of both? I assume the lift and spotting dish is mostly correct/relative for the more common front engine arrangement. Ideally the car center of gravity should be between the posts. So what do folks here do? I want to do what is most safe.
Gary
We put the front of the car with the short arms.
