I need ideally the insert into the dash that holds a Blaupunkt AM/FM in the dash. These are often referred to as DIN mounts. They are one piece and span across the entire dash radio opening.
I do have two ears that are held on to the radio shafts, but in order to successfully mount the radio behind the dash cover I will need to mount the radio from behind, thus the DIN mounting plate.
