Looking for specifications on gas tank air vent hoses. Need a purchase source and ID/OD sizes. I believe one is 16mm x 22mm. Thank you
What I can confirm is for 1968 SWB:
7x14mm from the tank to golden tube
4x7mm from the brake fluid reservoir into the little side inlet of the golden tube
LWB is different, I have no measurements for it.
I hope it helps.
BR
Claudius
Thank you Claudius :)
