Hi,
I have a starting issue with my car. It starts fine if I restart it fairly soon after its last run, even if its cold. I think my issue is that my 46mm carbs are draining slowly.
After leaving my car for a while the windows on the carbs show that the chambers are empty
Attachment 483136
Attachment 483137
After turning the car over many times, pumping the gas and finally getting the car to fire, the chambers are around 50% full, which is correct.
Attachment 483138
Attachment 483139
Is it expected that the chambers drain when the car is not used. I would expect them to stay half full. Any idea what could cause this?
Many thanks
Paul
