This is a good used original Motometer thermometer, small size 60mm housing, this is the gauge that mounts near the headlight switch, not the gauge pod, white face (could change to green), best part it is working well with an excellent temp sender with clamp, I put my hand around the sender and the temp climbs, holding accurate air temperature. Dated 10/66. Has mounting brackets. $800
