1972 911T For Sale
1972 911 T
Bahia Red Exterior/Black Interior
Original California Car.
Street/Track/Hot Rod 2191 pounds
Extensive Modifications:
911 SC Front Suspension with new ball joints, new turbo tie rods, plastic bushings, Sanders rifle drilled 23 mm torsion bars, Tarrett Engineering sway bar, 944 Turbo brakes, and Carrera rotors with new wheel bearings.
SC Rear Suspension with aluminum trailing arms, Sway-Away adjustable spring plates, Sanders rifle drilled 31 mm torsion bars, and rebuilt axle half shafts.
1978 SC aluminum engine completely overhauled-new bearings, chains,valves, and springs with reconditioned rods, European CIS Fuel Injection, Euro. racing headers, free flow custom sport muffler, new alternator, rebuilt starter, rebuilt and recurved distributor, new engine wiring harness, new fuel pump, lightened flywheel, Sacs Power clutch, and powder coated engine sheet metal.
Late fuel tank, relocated Odyssey battery, new oil lines and new thermostat with two front oil coolers.
Completely rebuilt 1977 915 transaxle (stock ratios) with newly rebuilt ZF positraction unit (8:31 rear axle ratio)
The body is fitted with metal RS flares in the rear and modified SC flares in the front (ala 911 ST), 8 point custom roll cage, Getty Design glass front bumper and glass rear bumper with aluminum sheet metal license plate panel heat shield, glass whale tail, all new body seals, light lenses, H-4 lights with show quality paint.
Sparco seats, Dietz belts, RS carpets and door panels, new ignition switch, SC instruments
Completely sorted, 1000 miles since completed.
Pictures at:
http://new.photos.yahoo.com/pordoc@s...60762329194188
$55,000.00/OBO
Call Tom Martenot at Deutsche Motor Sport 925-689-0232
