@rick
thanx for the offer, but your 'made in england' is not the original i do look for.
if you do compare the horses stature and the tail you ll see the differences.
Also the lettering of 'stuttgart' is not as defined as the original.
but quite nice so....
best regards
1 Attachment(s)
found an old ad, with the keyring up left corner...
cabrioenthusiast had the original poster fs here in the forum...
I see what you mean...and see the differences...best of luck in your search
I've had it stored away for years
1 Attachment(s)
detail of key from ad pdt
thanx to todd
bump.......4 - all look in their shelves...;)
2017 bump for old style key ring....
1 Attachment(s)
@all
found a nearby mint keyring, very nice so this search had found an end.
left one is a made in england copy, right one the original.
Does anyone can tell if this is an original Porsche keyring ?( the one attached with the key on the picture in the last post .)
thanks
Dear Donzenac,
if you compare the above original with your questioned item it is very obvious that a horse should at least look like a horse and not like a donkey..
this donkey key fob appears more often around the globe..
thanks Haul
Are you really sure of your what you are writing ?
I was told that in early 60s , Many Porsche keyrings were made in England - particularly the early ones.
It was only in the later 1970s that Heubach in Germany started to make their own Porsche keyrings with a slightly different drawing.
so i am just wondering where is the truth ... (?)
