I always find it useful to spend extra time making sure that the edges get good varnish coverage to keep moisture from wicking up between the laminations.
John, #332
73 S with sporto and 69 912 now out of rehab
John, #332
Nice job...I like detail stuff like that.
The Finnish birch plywood weighs less than perforated aluminum. The Factory knew what they were doing.
Just got done doing a similar thing to my Sporto Targa pedal board. That is an all but extinct part.
Is that a SWB sporto board?Quote:
Originally Posted by jt912
beautiful work
It is a '68 911 (US) soft window Targa pedal board. I've got a nice non-Targa board that I was thinking of cutting down to match the Targa but 1: it is just a bit differently shaped and 2: I couldn't bring myself to do it. So a sheet of veneer and two weeks of gluing and clamping later I was reasonably satisfied with the results.
That's great Bob, thanks for shareing i need to do the same when i get to the interior on my resto.
RHD wooden boards are near impossible to find.
I thought I wrote this on this thread, but it disappeared. If this is redundant, disregard.
I suggest applying several coats of clear urethane to the floorboard. This reduces the chance of the wood absorbing moisture and delaminating. I also applied urethane to some aftermarket door panels that used Luan plywood as the base structure.
Sherwood
Inspired by this thread, I tackled this too! Mine needed too much bondo to make stain practical, so flat black it is.
