Sellers reply below Clyde. Solid grommet. I will need to check the measurement.
"ie the inner diameter (small hole) is 15mm, but is stretchy and fits on a 30mm nut.
The outer diameter is 47mm and covers a hole of 40mm. If you buy, you get of course our
bank account! Sincerely urneunelfkonturug"
Dave
Pipe measures 27mm outer diameter, hole measures 47mm diameter
Looks like no good Dave if the plug outer diameter is only 47mm
Try PN 964 207 302 00. It's a dealer only item priced around 10.00 each. PET shows it
Try PN 964 207 302 00. Dealer only item but PET shows it. About 10.00
