Glad to help, as always...:)
Bill
Bill
I have 2 motors available. I will try to get them tested and also post some photographs.
Are you sure the motor is bad? Mine stopped working on my 72, I loosened up all the mounting bolts and it started working again, carefully tightened all back down and its been fine for 5 years since. Also make sure you have the rubber block in the door bottom which acts as a downward stop. Without it the mechanism can go down to far and bind up.
OK- Here is what I have. (2) Bosch - 0132001004 FRA 12v10 4500 U/min. So, not the same part # but it looks to be the same. These spin nice and smooth. Anyone care to chime in if these will work?
I'm seeing three different motors . . .
1) silverc4s . . .
...Bosch pn = 0 130 805 002
Identified as '70 electric window motor
2) nickb4 . . .
...Porsche pn = 901 624 102 01
Identified in PET as electric window motor up to '72
3) beaker . . .
...Bosch pn = 0132001004
Unidentified
I've been told that the '70 EWM is a one-year-only bit . . . and is 3-wire
Problem is . . . these all look like 3-wire
Let's see what moito comes up with . . .
Hi Rick,
Correction the part number I posted is 901.624.102.01 and according to PET is correct through '72
I just checked my motors and both work in both directions.
I would suggest sending those original non-working motors to Cuba - they can rebuild and make 50 year old technology work forever :)
