I wish you were around too Tom...thanks for that! It's pretty amazing what you can do when you have to. However, it sure never hurts to have a someone do a few things too though:D
Thank you!!!
Vic
Some proAttachment 223785Attachment 223786gress on our '72 (rally). Its just off for a touch-up on the paint and fitment of door panels then back to do some finish detailing.Attachment 223791 Will send some pictures later of specific detailing features.
Darn it! I see a speck of dirt on the distributor cap. :D
72Group4, that car looks super nice! Love the twin plug setup as well. We're living parallel lives with a silver/black 72 coupe. I almost went with an Amber shroud, but I ended up going with a red Series 900 shroud made for carbs (plugged MFI holes). I went with a long grey oil cooler duct from Damon too. Pics to come. Tom is right though...there is a speck of dirt on the cap:) Send more pics and details. My email address is gregbus911 AT gmail DOT com.
Attachment 224176 Its going to get very dirty in its first rally....but its clean right now.
At least you remembered to take some before pics. That car is so nice, it needs its own thread. I would certainly be following along! You'll have to post some post-rally pics as well. Did I mention that was a really nice car?
gregbus. thanks. once its near completion I'll post a set of pics including (importantly) pictures of the guys that worked on it....which is where most of the credit is due. I did the research and the scut work...the cleaning, stripping, degreasing and restoring of parts on the car, typically once a week, for over two years. They did the skilled work, in particular the fabrication work which is necessary if you want to use the car as it was intended.
It's been quite a bit since I've updated this post, but I've been doing things to the car. What I'm unable to do now, I've been stockpiling. Patience isn't exactly my strong point, so I had someone else do it. Bernie Buschen is the wrench for this one (and MANY others). I may as well have this stuff done right...the first time. He's got a lift...ability...the Porsche tribal knowledge...easy decision. In looking at what I've done to it, you might get the wrong impression. The car will be more capable than the driver at this point. I'm sure I'll still enjoy the heck out of it! While I'm not able to take full advantage of the capabilities today, my goal is to be able to tomorrow. Baby steps;)
TTG light grills - These are from Eric Linden (soterik). His outstanding work speaks for itself!
Attachment 269536
zinc coatings on front blower motor heater hose clamps
Attachment 269542
zinc coated hood and decklid latches - top and bottom. They even work...thanks to Chris and Bernie:) The front top plunger was off on the alignment so the trunk wouldn't open with the hood release. It closed no prob, but wouldn't open by pulling the release cable. D'oh! The plunger was off center and it took a little aligning to get it set. Manually pulling up on the hood, while releasing the cable, was what was needed. Works like a champ now. The rear tube for the cable fell down as well. The pull handle needed some mounting nuts to hold it in there too. All good now.
Attachment 269547
new door strikers - the little plastic piece I had in the original one disintegrated! Tough the doors still closed, it was certainly time for an update. The 12 point bolts on the passenger side was already stripped out, so a change was need there as well. Once they were aligned properly, all was good.
Attachment 269553
Elephant rubber bushings - Most replaced, but more to come later on.
plastic plugs for rear bumperettes - these go in the holes at the top to cover the Allen bolts.
Tarett monoballs - I decided to go with these rather than the stock camber plates. Time will tell, but I'm fairly optimistic that I'll still have some fillings.
Attachment 269560
Tarett hollow t-bars- 21 and 27 - These came from Elephant as well. 21s and 26s were a popular consensus. I ended up going with the 27s because it was what they had available and it was a little heavier with the additional displacement.
QuickChange spring Plates - QuickChange spring plates make fast-work of torsion bar re-indexing and replacement. Screw-type adjuster makes corner balancing and ride height adjustment easier.
Tarett front and rear swaybars - Fortunately for me, the car came with stock sways, so everything was already there and the bushings were still good. Just had to replace the existing bars with new bars and the adjustable drop links. With 40+ years of technology since then, they're a little lighter and stronger than the stock ones. For 40+ years to pass, there's really not that much difference. Those guys were way ahead of the curve back in the day! I like the fact that they are adjustable drop links now. At some point, the stock front sway was welded (rather poorly I might add) for a repair. Glad that's gonzo!
Attachment 269561
