Has anyone ever seen leather with this grain on a 911 dash before?
Attachment 437415
Attachment 437414
Attachment 437415
Attachment 437414
Looks like standard vinyl dash for '72 - '73 911's. Here is what elephant hide looks like for '68 so it is not that.
Attachment 437419
standard vinyl looks like the vinyl on kick panel and dash. This 911 was ordered with all leather interior, even door panels and back seats. This not standard vinyl.
Would be interested in seeing the COA for that car.
Here is the same dash material on a '73 RS just different grain of vinyl than what is on the dash and kick panel.
Attachment 437426
Well then i need a piece of that to make radio delete plate.
Should be the same as a door panel from same year. Check with Jim at EASY you could even use the material from the rear side panels. The vinyl on the early 914 door panels should be pretty close also. Maybe buy these panels and redo the whole dash.
http://www.ebay.com/itm/USED-ORIGINA...VYLwIF&vxp=mtr
http://www.ebay.com/itm/USED-ORIGINA...BYLxQX&vxp=mtr
If you can't find any get a hold of me. I have a door panel that I'm saving the material from to replace the vinyl on my dash. The door panel has a speaker hole cut in it which is why I'm using it , but I could cut a piece off for you.
Too bad you didn't post this a few months ago. I could have brought it to you if you had provided a place for me to watch the eclipse.:p
Thanks for all of the input. I found a pic of my 72T sold recently and yes, its the same stuff on dash insert. So its either a correct radio, which none is on the COA? Or match the vinyl.
I ordered a laser cut piece for radio block out. I would be very appreciative if there is anyone out there with that same coarse grain material they could donate. 12 sq inches. If so, private message me for shipping info. Many thanks in advance.
Stephen
