1 Attachment(s)
Easy Question - Hirschmann Antenna Rubber/Plastic body buffer/grommet/washer
I have removed the radio from a car which had it added after the fact bitd. A radio is useless in an air-cooled early Porsche when so much good music is played out back. :D
Short of welding the hole and painting the fender my intention is to make a dummy cover for the hole and use the same size plastic/rubber base used on the Hirschmann antenna. FWIW, the Hirschmann covers sold by Woody's won't do the job. A friend who runs a British shop gave a Dorman freeze plug and one of his fabricators tig welded a stud on it. It's a pretty good fit but I think I'll need to form one for the contour.
What I need to start is the actual plastic base piece which as of now haven't had any luck finding. This one is embossed "Made In Germany".
