2 Attachment(s)
Sorry to hijack the OP thread one more time, but as is is regrouping a lot of cool struff about the 906's...
So, last time, I showed the patterns for the front uprights, which are comon to 904 and 906. Here is a major step forward :D
Attachment 365742
Only a few gazilion parts to be done!
Here is another "big" part (not done by me, but a close friend, with the same addiction):
Attachment 365743
If i'm a bit lucky, I may show you an oil cooler in the coming months, as well as some other gearboxes parts!
Olivier.
4 Attachment(s)
Very cool part Olivier! Here are a few more photos of that Magnesium 906 gearbox casting.
Attachment 365763
Attachment 365764
This one was listed at $21,000 on eBay back in Sep 2013...
Attachment 365765
...and no clue on what the current market price-range for once of these completed could be.
Attachment 365766
Received these beauties from Germany this week. :rolleyes:
Not the same casting Armando. A completly new mold. And this one actually shifts.
If you want one, the price is much more reasonable. Not cheap but more realistic...
Olivier
Has a stress analysis been performed on the front uprights? The Porsche ones were a forging and probably with good reason
No stress analysis has been performed on the parts.
And you're right original ones are forgings. And my guess is that they were made from a not super uber hard steel, in order to be fatigue compliant, and not brittle.
The approach is the following:
Castings have the exact same dimensions, since the design is based on a 3d scan of a "real" one. All cross sections are then the same.
The alloy used is a high strenght chromoly, wich has the property to quench envenly in depth, and it is possible to chose in a relatively wide range of UTS.
Casting is less perfect than forging. Hence the parts will undergo 2 different heat treatments.
THe first one is clled Hot Isostatic Pressure. This treatment acts "like" a forging. It closes all the micro porosities in the part. Another side effect is to "anneal" the base metal. Hopefully grain size will grow, and be more even compared to a "as cast" parts.
Bigger grain size means lower caracteristics, but also has a good effect on toughness, and fatigue resistance.
Final heat treatment will give the parts its caracteristics. A medium UTS will be chosen for a good resilience, good fatigue resistance, and good caracteristics.
For information, the heat treatments alone are as expensive as the raw castings!
I am pretty confident the parts will be more than trustable.
Plus, I am not the first to make these parts in casting, and the feedback is good so far...
The steering levers will be billet machined in a lower grade steel, and hopefully in case of a small accident they will bend before the uprights.
Thank you for your input in this thread!
Olivier.
