Originally Posted by
patjolson
when I turn to the left I have a profound howl, either in or out of gear, its coming from the rear. Doesn't do it when I turn to the right. Not a tire rub 195 r6515. Michelins. Is it normal to have end play at both ends of the half shafts? I can see why you would have one end with play, but both? I am beginning to suspect either alignment or worn control arm pivot. The cv joints look solid and I can't see any obvious wear marks.This is a 20 year barn car that surfaced in September last, if that has any relevance. Yes the lug nuts are tight.
Any help is appreciated.
