Drive shaft/hub axle ? problem
I am getting a knocking sound from N/S rear on hard acceleration and a bit when coasting. Been there for quite a while.
Having jacked the car up with the handbrake on the O/S wheel will not move but there is a few degrees of movement (<5) when I try to rotate the N/S wheel. The movement seems to go right along the drive shaft to the gearbox end. The handbrake seems to be working OK on both wheels.
Where could the movement be coming from?
Any ideas welcome. 1967 911L.
