4 Attachment(s)
1969 Rear Light Housing Drain Hole
Hi Everyone,
I've just introduced myself in a separate thread covering the restoration of a 69S. Thought I'd ask this under separate title in case someone searches later.
When comparing the rear light housing drain hole, as well as on the unibody, on my 69 I notice the drain hole is close to the outer convex side, whereas on a 75 I have the housing/body hole location is closer to the concave side.
The mounted housings are 69's, the separate one is a 75 (or at least was on my 75).
I mention this because when I see housings for sale, they most often say 69 to 89. Which appears not to be the case if you want the drain holes to line up.
This may have been covered before - just an observation.
Best,
Sean
