Fall tri-state mini rally
Hello Erste folks,
I'm in the process of planning out a little unofficial, unaffiliated "mini-rally" for this Fall...a last hurrah before we're bombarded with the winter freeze. Starting point would be in Bucks County PA, running up into the Delaware water gap area, and then back down, however if you're farther north, feel free to jump in along the way. A route is about 75% done with some of the in between roads still being figured out along with stops for bites and libations. The tentative date is Saturday November 16th...hopefully early enough in the season to avoid frigid temps. So far I have about 10 cars in the mix. If you're interested in joining and receiving more info as it becomes available, send me a PM here or an email at michaelsmall215@gmail.com.
Best,
Mike
