8 Attachment(s)
Problems with plug wire lengths and routing
My new set of plug wires have different lengths then the originals and thus create a bit of a mess with routing them.
That being said I don't know the official plug wire paths and restraint methods.
Therefore I have 3 questions:
1: Does anyone know the original lengths of the wires? (elbow to tip)
2: Does any one have good pics of the original cable paths and restraints?
3: Is there any problem with reducing the wire lengths? The new cables have screw on elbow connectors at the spark plug end.
Any advice would be appreciated.
Thanks in advance.
Bob
Old set + new set = good set?
Thanks John,
That was really informative.
In pursuit of possibly saving a few bucks I disassembled my old cables and measured the resistance of the 6 spark plug connectors and 7 connectors at the distributor cap. This is what I found.
Spark plug connectors: 4 at 0 ohms. 2 at 1000 ohms.
Distributor Connectors: 7 at 1100 ohms.
So what I will do now is add the distributor connectors to the new wire set and I should be in good shape. I will have the 1K ohm distributor resistance and the 1k ohm spark plug resistance which was the original spec.
Glad I didn't chuck the old wire set. :-)
