Anyone know a current source for a ZF LSD to fit a 915 gearbox (1973)? Any condition. Thanks.
I think the P/N is 901.332.053.13 but not positive.
Attachment 437413
Attachment 437413
Yes, that's the correct number. It's the same LSD used in all 911, 912 and 914 mag case transmissions from 69 through 75.
As Steve mentioned on Pelican, you'll also need the correct 915 axle flanges for that ZF, which are 5mm longer than your standard 73 flanges.
Jon B.
Vista, CA
