is there a source for good 2.0L P/C out there? No chinese stuff. For my friend's 68 911L, 130hp. Just stock build, no hot rod.
How about an NOS set?
easier to upgrade to a 2.2?
911S? 911? 911T?
There are some available:
- Elevenparts has 911S or 911 Mahle pistons and cylinders https://www.elevenparts.com/mahle.php, US$ 4,010 for 911 Normal pistons with Nickasil cylinders.
- LN Engineering has several choices of Nickies with JE Pistons 9.5:1 or 10.5:1 compression ratios https://lnengineering.com/products/a...1-1965-77.html US$ 5,530.
I sourced JE Pistons for my 356A Super from LN Engineering. The engine hasn't exploded.
Thank you for the links Jim, it's for a 68 L. I'll try Marco first.
Jules -- I have set of 80 mm pistons and cast iron cylinders with pins that would have come in 69 2.0L 911 (not sure about 68) and 914/6. Reasonably priced. Taken from running engine.
PM also sent
