Can you upload a photo to what it looks like where the switch 'hit's the body to turn the light off? Also, can anyone show where the original wires 'came from' under the rear of the dash (I assume?). Thanks!
The trunk light switch pushes on the metal arm to turn it off. The switch is the same switch as used on the door lights (901.615.601.01). It provides a ground for the light when the door or hood is opened.Attachment 376596
Thanks Bill... my car has that little arm out the side but it's covered by the trunk lining. Anyone out there that can snap a photo of their original setup for the light? I'm thinking mine never had one...
Here is a picture of mine with the carpet in place. The carpet used to cover the arm. The clip and the routing of the wire I believe are correct.
Attachment 376723
