Clutch stop on floorboard
Hi all,
My clutch cable failed recently so the pedal dropped to the floor — luckily I was not far from home and with a friend so we were able to push the car back to the garage. I’ve now fixed this, it turned out the cable was only screwed in one mm instead of 20 mm at the pedal end, so it worked itself out. I’ve adjusted the nut at the gearbox end so the pedal has about one inch of free play, as described by Wayne Dempsey. So far so good, but the pedal travel is now much more than before.
I’ve now found out that there should be a pedal stop attached to the wooden floorboard but I don’t have it. I’ve ordered one but I have some questions:
- What are the correct bolts/nuts to attach it to the floorboard? Looks like they don’t come with the stop that I ordered and I’d like to do it “right”.
- It should be adjusted such that the cable travel is 15 mm, correct?
- Is it harmful to drive with more clutch travel than this? Can this damage the clutch or gearbox?
Thanks!
