Who is the “we” you keep mentioning?
Chris, is that you?
Nosism, from the Latin nos, "we", is the practice of using the pronoun "we" to refer to oneself when expressing a personal opinion.
Why the 3d degree interrogation? Bill has provided excellent technical info in all his posts period, end of story.
David,
Aren’t you the least bit curious about someone’s credentials? My questions are honest and benign. Again, Mr. Jones please feel free to PM me if you want to remain mysterious. Thanks.
(I never knew editing or censoring by mods could be done without a footnote on the bottom of the post? Message received Chuck. PM sent.)
Thanks again Bill for the excellent detail provided. I also have the lower placed bearing but was hoping that we didn't need to use it. Will fit the new top universal this week and if that isn't the cure then we move to the upper bearing.
Merv,
We're betting that it's not the bearing if it's a clunk or knock. Do you hear the noise when you turn the steering lock-to-lock with the front wheels off the floor? If not, we don't think it's the upper bearing.
Me thinks it may be near the steering lock on z column, not retracting properly! Just a guess. ..... cliff
I think Mitch Leland is making an upper bushing for the earlier cars now. His bushing for the 74 and up cars works great.
Thanks Frank and Cliff. It is more of as click than a clunk (hmmm). On the floor and off. And it coincides with some slight, visible movement that can be felt in the (original) upper universal. It has a little play in one joint that seems to be the source at this stage. It is about 45degrees each side of centre in the wheel turn. Good thought about the steering lock Cliff, will check but I have been over this whole set up carefully to identify the site of the noise. I am now pretty sure that the upper universal is the culprit. It 'could' be one of the balls in the upper bearing race if not the universal.
