How do 14" wheels lead to a more comfortable ride compared to 15" wheels?
Don
1970 911T
2006 Cayman S
Don
1970 911T
2006 Cayman S
The tire was taller on 14" wheels giving a little more shock absorbing in the tire.
Back 1969 a Car & Driver tested a 911T with 185HR14 tires against a 911E and 811S with 185/70VR15 tires.
- The nominal sidewall height for the 185/70VR15 was 70% of 185 mm = 129.5 mm or 5.1 inches
- The nominal sidewall height for the 185HR14 should have been at lest 80% of 185 mm = 148 mm or 5.82 inches.
The 14" wheel tire would have had ~ 14% more tire height to "give" going over bumps. I think--given equal tire pressures--the 14" tire would have been about 14% "softer."
