Brake options for 71T - with stock spindles
I have a 71T, very fresh all rebuilt chassis/brakes etc. All is basically new/refurbished with under 4k miles on it. Not stock motor. 2.7L.
Front end is Boge with Bilstein HD inserts, 21mm torsions, 18mm sways etc.
I'd like a larger front caliper with more pad area and heat dissipation for aggressive canyon runs
IIRC, the stock M caliper uses a D31 pad (I have porter field pads in it now) with a 2.4x2.2 pad area. The S have a 3x2.75 pad area (approx).
Am I correct options for the front brakes are:
Get S type front struts and an S caliper
The PMB Brembo AM bolt on for 3" spacing brakes
Get a carrera type strut and swap over the brakes and rotors, etc
Any other options?
thx.
