IWC made quite a few Porsche Design watches as well, including the Ocean 2000, watch for the german army divers.
Wear it with pride Jim ! I especially like the patinated PVD finish on it.
The really interesting thing is, that the tachymétre ring is in "miles", so it is obviously an edition for these markets.
Have not seen it before.
get cleaned and adjusted, "small service" . . .
You have one of the earlier configurations of the PD Orfina chrono. You can see the differences to the 5100 models. The chrono dial at 12, the i mile marker on the tach ring, the hands, and lack of secondary sweep hand. For an early model its in pretty good condition. I believe the 7750 is smaller than the 5100 maybe 42mm vs 44mm.
I used to wear a vintage Rlx Sub but the PD chrono is (surprisingly) much more comfortable, and to me less ostentatious. I wear mine every day, it keeps better time than all my other automatic watches. I had it serviced and re anodized at Superior in March 2018 which cost around a $G
Mine, in miles and loads of patina, I would argue unrestored since 1976 (perfect to me)- works perfectly and I wear nearly every day.
Attachment 509663
Attachment 509740Attachment 509741
The 5100
on my two ORFINA branded is the KM tachometer ting,
but also on the PD branded ->
below the KM tachymetre, straight end hands
Orfina Porsche Design was available with two movements -
first with the Lemania 5100 (Ref. 7176s) and later with the Valjoux / ETA 7750.
The Lemania 5100 has a subdial with a 24-hour display are generally somewhat more expensive - both in terms of purchasing and revising the movement. Also the large "pointed" hand on the 5100 is different to the "square" end of the 7750
Every free watchmaker should be able to repair the Valjoux / ETA 7750 almost at a fair price.
Depending on the variant and year of production, these watches have different logos on the dial, the case back, the clasp and the crown. A distinction is made here between the Orfina lettering on the dial in combination with the "Orfina flame" on the crown, bottom and clasp - and the uniformly used "PD logo", which stands for "Porsche Design"
But there are also watches in which the dial logo and case back do not match. According to the successor company Schifferle & Schifferle GmbH, this is also correct. There had been watches that had an Orfina dial and a PD bottom. Or vice versa.
In addition to the "civil" watches, there are also military versions - these like to be marked with the round and red "3H" markings on the dial. It stands for the used and weakly radioactive illuminant tritium. As far as I know, this luminous material was a little more radiant in military watches than in the civilian versions - the labeling should indicate this
Xavier and the OP have 7750. That is why they have the same sub dial configuration and KM Ring, The 5100 i posted has different hands and an additional minute recorder hand that has semi circular wings at the pointed end.
Attachment 509804
Prices have cooled, even for the military watches. But in terms of time keeping reliability, quality, and timeless German styling they are such great value versus other more expensive watches I've purchased. I am searching for the titanium 3H one Lew (Sonnett) on here has.
