More gear box number and type questions
At the risk of turning into one of those new members who only seem to ask questions about one subject, I have another question about my gear box number. I have every reason to believe it and the motor are original to the car, the engine number and model number fall into the right range, but the gear box number has been ground off over time. I'd like to confirm from PCNA that they are indeed the originals, but evidently now you pretty much have to give them the numbers and they confirm it.
The box is out of the car, and the techs at Steinel's here in Ohio are pretty comfortable thinking that the almost illegible gearbox number's last digits are 8064. This is reasonable considering the serial number range and it being a 1973.5 911T with a fairly late (estimated) build date. But the first few digits are unreadable.
So my question is, does the casting number on the box give any clues to the model number? Tech Specifications lead me to believe it's either a 915/02 or 03. The difference is "shaved" versus ground gears, which I don't understand. The casting number on the gear box is 915301102 OR.
Thanks in advance to all for your answers.
Bill S.
