St oil catch tank 1972
Can anyone please provide detail as to the flexible pipework connections to an oil catch tank for a 1972 ST replica.( this is different to pre 1972). I believe that a late washer bottle is used and located to the right hand corner of the engine bay against the inner fender. Diagrams and/or photos much appreciated.
Thank you
Saskia
thanks for the detail fellas
Thanks Russ & Bullethead. Neither of those help. One is in a later car and does not have the same oil lines projecting through the inner fender and the repro catch tank in the other example is a pre 1972.
