4 Attachment(s)
Recaro LS seats & stock seat belt...thoughts please
I am nearing the finish line on my 72 hot rod that will use Recaro LS seats. Seat-to-floor mounting brackets fit fine, but I remembered that the stock seat belt anchor bracket and seat belt receptor bracket are designed to mount on the seat (rather than the seat bracket). I discovered that the Recaros - since they are a universal seat - don't have pre-drilled & tapped holes to mount the original seat belt anchors/bracket, but they do have a pair of holes on each side of the seat underside (covered in seat fabric now) that are in the proper location for seat belt brackets. The stock brackets are also not long enough to reach these mounting areas and I'll have to mig-weld some added length to them and install nut-serts in the available pair of holes on each side of the seat. I've attached some photos. Before I proceed, I thought I would see if someone has 'been there, done that' and agree with my plan or have another idea. Thank you.
