Has anyone attempted a full dismantle and re assembly with black plastic rivets on an air cleaner cover on
an MFI 73?
If so details/pics please.
an MFI 73?
Hi Clyde, I have done several of these in the past. I have not removed the plastic studs completely just trimmed around the heads enough so I could pull the metal plate off leaving as much of the plastic stud as possible. Then I had the metal piece stripped and powder coated replaced it on the plastic studs then heated up a 1/4" punch and re-melted the tops of the plastic studs to create a new head.
OK that works I guess
The problem is the plastic rivets were never painted originally , so I do some careful masking .
The melting process of the plastic studs duplicates the original process exactly. If you look at the original stud tops they are shaped differently.
