2 Attachment(s)
FS: Porsche 2.8 Engine 46IDA, 92mm RSR Pistons, Twin Plug
This engine has sold. Thank you 911s registry.
I am selling a Porsche 2.8 Engine. I was never given any of the build receipts, records or any other documents with the engine but here are the details that I do know.
Here are some pictures
http://s263.photobucket.com/user/MrB...orsche28engine
This engine is still installed in a 914 and it starts right up and is a very smooth engine. It makes great power, does not have any leaks, and appears that it has very little use on it. Here are the specifics.
Built on a 1974 7R 911 Case
Weber 46IDA3C Carbs Made in Italy. Matching L9 and K9
Twin Plug with Bosch Distributor and MSD goodies
92mm MAHLE RSR Pistons/Cylinders
S Cams
1969S Aluminum Pressure Plate
916-6 Oil Cooler
Updated Pressure Fed 930 Tensioners.
Race Headers/Exhaust.
This is a complete drop down engine assembly.
Asking 12,500 for the engine or 15,000 for the complete engine/914 transmission with LSD, 914-6 oil tank etc.
Located in Concord California.
