1 Attachment(s)
1973 T - Where does this wire go and am I missing studs?
I forgot to take a pic of where this wire is attached (see pic). It branches off the wire that clips onto the distributor. I am thinking it must be a ground to one of the chain cover studs?, but does anyone know for sure. I assume it it would be easy to tell from a wiring diagram, bu they all seem so low res that I can't tell. Also with the Carerra tensioner kit covers, on the top left there are two open holes (see pic)that look like stud holes, probably for if you have smog pump, but are they required to hold the cover tight with no smog pump? Seems like too long a span without studs/nuts in those two holes so I assumed so, but feels like holes are blocked. I had ordered the M8 50mm studs, but it feels like the is no actual hole beyond the cover? Any ideas? thanks
Attachment 512704
