3 Attachment(s)
FS: 73T Targa MFI Race Car
This is a strong running 1973 MFI t with what I believe to be the original engine and transmission (I dont have the COA but the numbers are correct for the year). The car is rust free but it has had a mediocre repair of a right front collision. I do not have much history on the car, but here is what I do know:
It has MFI with the throtile bodies bored to 36mm, and a "2.7" scribed on the tag on the pump (I assume it has a 2.7 space cam but no way to confirm.
The engine has high compression 86 mm pistons, ported heads, "mod S" cams, and boat tailed windage mod on the case. The case head studs are time- serted.
It has the ultra light all aluminum pressure plate (not the alimunum/steel sport plate).
It has 30mm rear torsion bars and green bilsteins, SC calipers, the front bars are larger diameter than stock but I don't remember what they are. The car is a very competitive vintage race car located in Fort Worth, Texas. Priced at $29,000. Please call me at 817-932-5492 if you have any questions.
