Gasket / Seal on Front Turn Signal Housing
Hi Everyone:
I am about to replace the gaskets on my front turn signal housings and had a few questions before I started the process. Rest assured, I have the Genuine Porsche parts for the job. :)
1. Does the housing need to be removed from the car to install the new gaskets?
1a. If so, is the housing held on by just the 2 screws that can be seen with the lens removed?
1b. If one screw happens to snap, what are the details/sizes of the screws?
2. Does the new gasket need to be glued to the housing?
2a. If so, will standard 3M super glue do the job?
Thanks in advance!
