I have a 1967 coupe with a torsion bar tube that is rusted in the middle section. It is also missing the steering shaft cover.
please PM if you have these parts.. Thanks
Chewster PM sent.
You have a PM, not sure where you are located, I have a 68 Targa with solid seat pans torsion tube and much more I need to make go away. Pics available
I will have both.
once OP sorts his pics, I will be in torsion bar tube. My 69 911E is bit disastrous in there.
After a couple of possible leads have not worked out, I am still looking for these pieces. Please let me know if you have. Thanks
OK found the steering shaft cover. PM sent.
