10 Attachment(s)
FS: 1973 911t sunroof coupe
SOLD!
Available for sale is this 1973 Porsche 911T in Light Yellow/62 with black leatherette interior and recaro seats.
This car received a complete restoration minus the paint. The car was completely taken apart and inspected then put back together with new seals and clean hardware.
Engine is a 2.4L mfi that is original to this car. Upgraded to hydraulic oil fed tensioners with a new clutch and flywheel. This engine has no leaks and is extremely clean underneath. A cylinder leakage test was performed with very good numbers all the way across.
Throttle bodies recently done by Eurometric and mfi pump serviced by MFI Works in Oregon. Documents will be included for everything serviced and bought for this car.
The undercarriage of this car is in concourse condition. It has been completely redone back to factory specifications . Suspension components have all been refreshed or replaced.
The transmission was replaced with a 915 from a 76 car. Transmission has been inspected and all gears shift perfectly and smooth with no grinding. New shifter bushings and sleeves also done make for a very comfortable driving experience.
A new carpet kit was installed along with a re-wrapped dash, knee pads and steering wheel. The rest of the interior is original to this car including the headliner and seats. This car has a dealer installed AC system that has been upgraded to a r134a system.
This car has won several PCA events here in Arizona with score sheets available.
PPS certificate for this car includes all the options it came with from the factory.
Asking $100k
Open to reasonable offers
Car is located in Arizona
Attachment 500826Attachment 500827Attachment 500828Attachment 500829Attachment 500828Attachment 500830Attachment 500831Attachment 500832Attachment 500833Attachment 500834Attachment 500835
