I just cleaned up seat rails and I beleive should have some protective coating. Are they anadized?
Attachment 425209
Attachment 425209
Mark Smedley says those are among the few parts that are actually still cad plated.
Ed -
Is there a time period where the cad stopped being used? The ones on my '73 sure look like zinc to me!
- Rob
Back in the early 70s I had the rails from my '70T analyzed by two platers and a metallurgist for Champion Spark Plug who just happened to be a PCA member and concours guy.....definately silver cadmium. Multiple restoration projects up through '73 cars...all silver cadmium. Always curious why cadmium....my metallurgist pal suggested that cadmium is softer and created less friction....they were sliders! Subsequent SWB projects and research also confirm cadmium.
The ones in my '65 coupe were silver zinc. Not an opinion but verified through a plating testing kit given to me by Tim Goodrich years back
So these are for my late '65, '66 model year 911.
silver zinc or cadium?
The actual build date would only be partially helpful as this is a supplier issue...not a factory specification.
An educated guess would be to survey the original fasteners in the car. These cars were being built with fasteners who's industry was changing it's specifications, not only actual DIN dimensions but plating.
If your car was built with predominantly clear (silver) zinc fasteners, go with silver zinc. If you have a lot of later yellow zinc fasteners, go with cadmium on the rails.
The other issue is that the current zinc plating process results in zinc that is a bright bluish finish...far different from the older dull silver of the original pre-EPA process. If you went with "new zinc" you'd have top knock it down a bit to flatten it.
In the old days silver zinc and silver cadmium were VERY similar when fresh..thus the confusion. One way to differentiate is old zinc dulls and blackens with break through ferrous oxide. Old cadmium chalks with a white powdery residue and break through rust.
Thanks Mark. Very helpful. These are for #302580 with a build date of 11-2-65. The allen screws are silver color, not yellow.
The blue finish on zinc plating is a chromate that is similar to yellow chromate. The chromate is a protective coating to help prevent oxidation of the raw zinc. Zinc plating is silver when it comes out of the bath until chromated or left as-plated.
I am sure you could direct your zinc plating provider to leave parts "raw".
