What will be left if the original body, if there was something from the previous restoration?
How do you manage to find the right dimensions and shapes?
Impressive work and thank you for the update.
Door lock refurbish and install.
http://forums.pelicanparts.com/uploa...1540400581.JPG
RH side build process and checking fixture ,patterned from the correct LH side
http://forums.pelicanparts.com/uploa...1540403174.JPG
Knocking over the interior corner flange with aided jig.
http://forums.pelicanparts.com/uploa...1540681628.JPG
http://forums.pelicanparts.com/uploa...1540681107.JPG
offering up the windshield and side window
Dry fitting and tuning as we go along to keep everything in check.
http://forums.pelicanparts.com/uploa...1540681905.JPG
Flange tooling to rear body.
http://forums.pelicanparts.com/uploa...1541287606.JPG
Anneal and knock in
rear body set on flange for fitment check.
Flange detail
NOW HIRING
Fully skilled metal workers
Entry level metal workers
apply to Jon@themetalsurgeon.com
or Valerie@themetalsurgeon.com
Benefits including Health Care
thank you!
A Post with glue ready to bond
http://forums.pelicanparts.com/uploa...1541735472.JPG
Open A Post area ,ready to take A post
Overview
Setting in position / Angle finder
Inner A post frame structure
http://forums.pelicanparts.com/uploa...1541857745.JPG
LH A post glue in
