Item is NLA, will be using it...
Hi, will this fit on a 68 ,912 ?
Fit? yes. Fit without some sheet metal adjustment? no. As was the case with the original 911R parts, you will have to use a grinder to enlarge the opening in the tail light buckets.
So if you're obsessed with keeping your 912's body metal original, this is not for you.
On the other hand, if you do the mods, I'm pretty sure you could still go back to factory lights at a later time...
Can't say for sure, because I like the 911R lights so much I still have them on my car 10 years later!
Adam912.Out.
'66 912, 911S suspension, 2.2L T4 motor, 495K miles and lots of fun!
Hi, have the taillights sold?
I have a tentative buyer - will be able to confirm very soon. Watch the ad, I'll pull the "SALE PENDING" if it falls through. Thanks
