Tracking down oil leaks, mostly successful so far. Next one I'm focusing on is at the intermediate shaft end cover. Looks like I need to replace the gasket there, and maybe some sealant at the 3 bolts, or fresh aluminum washers?
In any case, first question is whether I need to drain the oil prior to removing the cover? I still want to put a few more miles on the break-in oil before changing it, so if I need to drain it to change that gasket I'll wait a bit.
