Windshield spray nozzle installation
Hi all, funny to admit these little devils are not cooperating. I have a 71' and using what I believe is the proper chrome topped nozzles. Problem is that the installation is not as simple as one would expect as the small groove in jets is not seating
properly. Just painted so thinking the paint was too thick so removed down to primer around the hole. No luck. Trimming them is a possibility but wonder why I would need to do this. Soap, no help. Thinking of putting them in hot water to soften the rubber but hoping you guys have a trick that works. Thank you.
