Hi All,
I have a 71T with H+H rear sway bar. The bushings on the drop links are perished. Any idea where I can find them or what I can use instead? I hear Weltmeister bushings plug and play. Alternatively, if I want to replace the entire rear sway bar, what do you suggest for cruiser setup that does once a year track? I do hit the twisty roads in CA fairly hard and often.
