As I said I only saw it once so will rewatch. But two things: 1. It seemed the Porsche has another quarter width high to go; 2. It’s an amateur race and you have to be careful passing high and leaving no out. The consequence shouldn’t be potentially fatal especially around an open wheeler. Putting yourself in a situation that has this sort of outcome potential seems to be a mistake. These aren’t pro drivers. It’s acceptable to drive another car close to the wall to preserve the best line - as long as they had some safety margin. You aren’t taking the overtaking drivers line if you preserve your own. But if the open wheel moved out of his line then that’s a problem agreed.
