WTT: Unusual parts to trade, and RSR and 4-cam parts
I have two lists on Excel, one is a Wanted list of RSR and 4-cam parts. The other is a list of 100 more or less somewhat exotic porsche parts for 356, 4-cam , RSR and ST that I want to trade for parts that i need. I cannot find a way to transfer the list to a Registry Forum, but I can email the lists to interested parties. If interested please send me your e-mail address.
Mike Curnow
Mike's Parts Wanted List...
MIKE CURNOW
mcurnow@comcast.net 3 Irwin Dr. Coatesville Pa. 19320
1973 CARRERA RSR 2.8 & 4-CAM SPEEDSTER PARTS NEEDED
RSR FRONT ALUMINUM FORGED CROSS MEMBER - AXLE
RUBBER BUSHINGS for THE MFI PUMP MOUNTING PLATE - 911 113 121 00 OR 901 343 783 00, I THINK
RSR 92MM MAHLE CYLINDERS AND PISTONS - TRYING TO COMPLETE A BROKEN SET - NON GROOVE CYLINDERS
RSR MECHANICAL TACK CABLE - OR AT LEAST THE LENGTH OF THE CABLE - 911 641 511 02
HOOD PROP UP KIT - 964 CUP CAR or RSR
ORIGIONAL 1973 RSR DRIVERS SEAT - black cloth , no headrest, no adj. 911 521 903 02
RSR ECCENTRICS FOR THE REAR SWING ARMS - to adjust bannana - they have a hex head , not allen 911 333 145 00
RSR ECCENTRICS FOR THE REAR SWING ARMS - to adjust bannana - they have a hex head , not allen 911 333 145 01
NUTS FOR ECCENTRICS
GLAVERVILLE REAR SIDE 1/4 WINDOWS and frames
SIDE 1/4 WINDOWS ALUMINUM TRIM LOOKS LIKE THE 1/2 ROUND TRIM AROUND THE WINDSHIELD
RSR QUICKER STEERING RACK AND PINION
HEINZMANN FIRE EXTINGUISHER SYSTEM - HANDLE AND CABLES ,TUBING, BRACKET BETWEEN SEATS
ONE STEEL HIGH BUTTERFLY AIR HORN , CHROME PLATED
FOUR HIGH BUTTERFLY AIR HORNS, STEEL WITH GOLDISH PLATING
RSR 915 TRANSMISSION SHIFTER - May not exist
1973 RSR BEHR OIL COOLER - in & out holes-30mm- on end facing passanger side of car
RSR RUG KIT
DARK BLUE CARRERA SCRIPT - APPROX 69 inches long , PORSCHE AND CARRERA SCRIPT FOR ENGINE LID & BUMPER TAPE
ROD BOLTS AND NUTS - REUSEABLE
356 4-CAM ALLOY STEEL WHEELS
356 4-CAM ALUMINUM MOON HUB CAPS (4)
356 4-CAM 1956 TOOL KIT
Mike's Parts For Trade List...
MIKE CURNOW
POSSIBLE RSR, 4-CAM, and other unusal parts for trade
mcurnow@comcast.net PHILA PA. AREA
RSR 915 TRANSMISSION COOLER HARD LINES
RSR 915 TRANSMISSION SOFT LINES
RSR 915 TRANSMISSION PUMP NON OUTSIDE COOLER RE-CIRCULATING PUMP COVER
RSR 915 TRANS PUMP GEARS
904 ,906, 910? MECH chrono TACK - 10,000 RPM -BLACK FACE GREEN NUMBER not for sale yet
ELVA PORSCHE MECH chrono TACK - 10,000 RPM not for sale yet
SCHEEL SPORT SEATS, with adjusters & sliders
1973 RS LIGHTWEIGHT FIBERGLASS REAR BUMPER NOS -FACTORY
1973 RSR FRONT ALUMINUM LOWER VALANCE - NOS - FACTORY
ONE PAIR OF PALLAS CIBIE ORIGIONAL HOOD LIGHTS - USED
NOS RSR EXTENDED REAR BANNANA TORSION BAR TUBE - Factory not for sale yet
1 FACTORY NOS MEGAPHONE - 911 111 044 00
NOS FACTORY ST ALUMINUM DOOR SKINS - BOTH DOORS
906/910, OR MAYBE 908 FACTORY OIL COOLER -BEHR -FOR IN THE NOSE not for sale yet
906 CRANK not for sale yet
2 LITER FORGETRUE PISTONS, NOS SET OF 6 not for sale yet
SPYDER 718 LTD. SLIP. CENTER SECTION 718 332 535 00 NEEDS REPAIR
718 SPYDER LIMITED SLIP PARTS
901 LIMITED SLIP OUTSIDE CASE - NOS
356 LIMITED SLIP PILLS - ONLY 3 OR 4
901 LTD. SLIP INTERNAL PARTS
RSR 1973 REAR BRAKE TOP HATS
RSR BRAKE DISKS
2- HIGH BUTTERFLY STEEL AIR HORNS - LOOKING FOR 4 MORE not for sale yet
SET OF NON-ADJ ROCKERS not for sale yet
2 -1973 5 BOLT RSR FRONT BRAKE TOP HATS
RSR PASS SIDE REAR CENTER LOCK SPINDLE
SOME ENGINE FIBERGLASS SHEET METIAL
PRE A 356 SPLIT CASE TRANS
RSR/917 BRAKE CALIPER PIECES - FRONT SIDE WITH EARS - BLEEDER REPAIRED-VERT FINS 42MM
SAME -REAR SIDE WITHOUT EARS-VERT FINS 38MM
SAME -FRONT SIDE WITHOUT EARS-VERT FINS-BLEEDER REPAIRED 42MM
SAME -REAR SIDE WITH EARS-VERT FINS-BUSTED UP 38mm
SAME -REAR SIDE WITHOUT EARS-HORIZONTAL FINS 38mm
SAME -FRONT SIDE WITH EARS-HORIZONTAL FINS-BLEEDER REPAIRED 38
SAME -FRONT SIDE WITH EARS-HORIZONTAL FINS 42mm
SAME -SPREADER BLOCK SMALL FINS -HOLES FOR EMERGENCY BRAKE
SAME - 3 SPREADER BLOCKS, SMALL FINS
SAME - 2 SPREADER BLOCKS, LARGE , SMOOTH SURFACE
SAME - 2 SPREADER BLOCKS, LARGE , SMOOTH SURFACE - NOS
RSR/917 BRAKE CALIPER PISTONS
VDO ELECTRIC 10000 RPM TACK - ANDIAL PRINTED ON THE FACE - post late 1973 no silver bullett
2 MECH 10000 RPM JONES TACK FOR 911
JONES RIGHT ANGLE TACK DRIVE FOR THE JONES TACK
FUEL CELL
3 LITER RSR ENGINE CASE not for sale yet
3 LITER RSR ENGINE CASE - HOLE IN SIDE not for sale yet
4-CAM - HAND GERNARD OIL FILTER
3 LITER RSR HEADS not for sale yet
3 LITER RSR CYL AND PISTONS - MAHLE not for sale yet
3.2 LITER RSR CYL AND PISTONS - MAHLE not for sale yet
1 HELLA 139 DRIVING LIGHT - NOS
SPEEDSTER DOORS not for sale yet
EARLY 911 GOLD 2 PIECE PORSCHE ENGINE LID SCRIPT
EARLY 911 ALUMINUM AND WOOD STEERING WHEEL
NOS 110 LITER GAS TANK SENDING UNIT - RSR
934/935 FLAT FAN SCHROUD
911, NOS FRONT TRUNK FLOOR, VIN IS 90150103523 superceeded to 91150103511grv
911,912 NOS PASS SIDE INNER FENDER WELL, WITH BATTERY BOX, 1969 TO 1973
616 211 021 01 NOS left side, driver side , euro heater box for a 912
2-RSR CAM HOUSINGS not for sale yet
LOOKING FOR ONE CHROMED HIGH BUTTERFLY AIR STACK
911R - NOS hard oil line running towards the back of the car
( 2 ) Alloy steel wheels for 356 4-cam not for sale yet
Set of 356 Annular disk brakes for a( B) 4-cam car
356A G/T big gas tank not for sale yet
356A 4-cam oil tank not for sale yet
NOS Solex Center Lube Camshaft 901 195 110 01 right side pass side
Sportto Trans---925/00 serial # 7630156
PAIR OF 2.8 RSR USED FACTORY REAR FLAIRS
356 NOS PLEXIGLASS FACTORY SIDE WINDOWS
ST or COMPETITION CAR OIL FILLER NECK 901 107 640 03 NOS
356 2 liter 4-cam oil system - only one cooler not for sale yet
1974 / 75 RSR OIL COOLER not for sale yet ?
G/S 1500 roller 4 cam engine complete - Serial # P90572 ?
G/T 1500 roller 4 cam engine complete - Serial # 90828 ?
ELVA flat fan 82mm roller crank 1750 cc engine, needs some repair - Serial # P90418 ?
ELVA flat fan pea shooter exhaust ?
New RSR rugs not for sale
912/356 NOS European heater box, 616 211 021 00 left side (driver side )
356 4-cam 8000 RPM Tack
1965 911 Solex engine # 902576 - no intake, engine is apart
