Attachment 232831
I know it should be a tight fit but damn. Should I remove the inside upholstery covering the wheel well to get the front mounts anchored and then reinstall it? The mounting plate seems to overlap a bit onto the vinyl. Also, is there a trick getting the rear bars to the seat belt bolts? I'm not racing, it's just for looks. Thanks
