Looking to locate 38mm throttle valves/Butterfly...
I see this part is available, but not sure its 38mm. 90110096602 ?
When I put that part number in at sunset it seems to be coming up as a screw of some sort. Maybe I missed something?
https://www.sunsetporscheparts.com/o...ew-90110096602
Based on that part number it is for the screw that holds the butterfly onto the shaft and not the butterfly itself.
The butterfly is part 901.100.965.00 and I would guess for 40mm carbs so not the 38mm you are looking for.
Why are you afraid? Do you think someone sleeved your carbs down to 38mm?
I'm assuming you want a 38mm butterfly for your MFI.
I'd get in touch with Matt from Eurometrix to see if he has an extra throttle plate available for you.
Warning: After seeing the pics on his website you may be inclined to just package up your entire system and send to him :D
https://eurometrix.ws/
I think the 38mm would be for his throttle bodies being a 71S, not carbs.
