I suspect you will be better off with the EFI unless you rebuild the engine to better suit carbs. Different pistons and cams would be needed to work well with carbs, I suspect.
Though you may not be versed with engines, you will probably gain foundational knowledge of detonation if you absorb some basics now. Reducing compression a nominal amount to 10: 1 would probably be wise, regardless of octane. Some insight here :
https://jalopyjournal.com/forum/thre...mp-gas.291798/
I can see your thirst for carbs, but at what cost (money, time, experimenting, etc. not to mention anquish, worry and frustration). With a car like yours just go stock 3.6 and call it a day. I'd backdate the heat, put SSI's on the car and rock and roll. Next, rebuild your gearbox with shorter gear ratios :) and a guard lsd, lots of upgraded internals, maybe a collant pump if you plan to track it, and go live the dream. Ask yourself, do you take the blue pill and all goes back to normal and you don't own a Porsche. Take the red pill and I'll guide you down the rabbit hole to the slipper slope of Porschephilia, recently certified in the Physician's Desk Reference manuall as an addendum to describe men of our ilk :)
Hahaha, Ill take two red ones :)
You are right, I thought it was just buying the pmo kit, plug and play... I will just leave it like that. Today the rsr finish braids came in with TB's and next week the car will be picked up by Leo - Madeno Racing (ohlins center), his work is fantastic, can't wait to finally drive the car.
About that 964 engine: it was installed in 1990, so I think it is the first 3.6 conversion ever?
Here some more pictures (paint on roof, bonnet, bumpers, under- and inside seems original)?Attachment 498624
Today we fitted the braids, next week suspension and geometry Attachment 498693
Very very cool car, love the color and the Braids. Now get out there and drive it, get it dirty! Don't worry about making the front bonnet perfect. Don't paint it. Love the patina of the chips on the leading edge of the front bonnet/bumper. If you are afraid of rust or can't stand the look of patina, hire a pro to respray. Your front bonnet and bumper are way past the touch up paint stage.
